Old 03-21-2012, 06:27 PM   #7 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by 2000neon View Post
As for longevity, the motor already has 200 000 kms on it, and the body has only got about 1 summer left in it..
I am intrigued about the oil though, is there an actual oil feed line, do you know if it would be possible, or reasonable to actually take care of the oiling issue?
Yah, it's the pivot shaft.
If you remove the rocker arms, you'll see holes in the pivot shaft that feed the rocker arms. If you're going to leave the arms off, you'll need to plug those holes. Otherwise, your remaining rocker arms will rather quickly fail and your engine will run like garbage until it dies.
