I have been thinking about the idea of cylinder deactivation, and I understand that the only successful route to take is by disabling all of the valves to basically make an air spring with the "trapped" air, as well as cutting off fuel.
I was thinking about fully deactivating a cylinder, not just at cruising speed. The car in question is a 2000 dodge neon, with a 2.0 liter, 4 cylinder, 16 valve motor. The idea that I'm thinking about would be to remove the rocker arms for the valves in that cylinder, and then pulling the electrical connector to the injector.
By removing the injectors, it would disable the valves, and the springs would just keep them closed, and removing power and/or ground to the injector, the fuel supply would be cut off.
In theory, this should work. The cylinder pressure from the trapped air would keep enough pressure on the rings to prevent excessive oil burning.
The lack of air into the exhaust would prevent faulty O2 sensor readings.
If this was done for cylinders 2 or 3, there shouldnt be too bad of any "hot spots" by the lack of combustion, as the aluminum head and coolant flow should keep things moderated.
A lock of power shouldnt be
too much of an issue, the motor would still basically be a 1.5 liter with a heavy rotating mass
And at 130 hp, cutting off 25% would still leave 97.5 hp, which would be enough for basic daily driving duties.
Balance could be an issue, although with the deactivated cylinder still being there, the piston and rod would keep things in balance except for the "kick" from combustion. - but lets be honest, these neon motors all shake a lot anyways
The only thing that I can't picture in my mind is the actual rocker arm setup. The majority of my engine experience is with older Chevy motors, with a very simple pushrod design, which would allows for extremely removal of a rocker, but I dont really know how these neon's valvetrains are set up. Also, do the neons use a shaft mounted rocker? Would it be possible to remove only some of the rockers?
What do you guys think? Is it worth the cost of a valve cover gasket and some time?
