Old 03-21-2012, 06:40 PM   #9 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
This picture should help.
If you remove the rocker arms for #3 cylinder, you'll need to install sleeves over the pivot shafts to replace the rocker arms. Otherwise, the oil supply will just shoot out the bare holes in the pivot shafts where the rocker arms used to be, and you're going to end up starving the other valvetrain components.
The Following User Says Thank You to t vago For This Useful Post:
MetroMPG (03-21-2012)
