Old 03-23-2012, 08:30 AM   #31 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
When I do lay ups I cover the surface with rip stop nylon or polyester fabric. On compound curves I use strips about 2 inches wide. It produces a smooth surface and makes sure that the edges of the composite are embedded in the resin, just peel off the cloth. If another layer is required you have a great surface to do a secondary layup, no sanding.
Some hints I would ad is to make sure you don't have any wrinkles in the fabric. Dont stretch the fabric as it causes the layup to distort.
Noah Webster, 1787
