Old 03-23-2012, 04:48 PM   #5 (permalink)
oil pan 4
For harder piston rings you could always go with tool steel rings.
They are pretty hard, I believe you need about a #400 finish on the cylinder bores to break them. Normal bore finish these days is done with #800 grit stones or finer.
