Old 03-24-2012, 01:10 PM   #11 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Vekke View Post
I agree that effect to diameter does not have measurable effect, but what about the aero?.
I have my own eco tire designed for less aerodynamic drag wise plus some other tricks, but Nokian Tyres did not see that that kind of tire would fill their requirements for tires they have.
I'd think they can save far more fuel by concentrating on RR.
In order to keep the contact patch the same, the rim would need to be wider and the tyre would be stretched wider than necessary - that would give it more frontal area than needed - so that extra drag would need to be overcome before any benefit will show.
On 100mm of sidewall and 10°, you're looking at 18mm each side, that's a bit of stretch but I've seen worse on ricers.
