Old 03-24-2012, 12:10 PM   #11 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Vekke View Post
I agree that effect to diameter does not have measurable effect, but what about the aero?.
I have my own eco tire designed for less aerodynamic drag wise plus some other tricks, but Nokian Tyres did not see that that kind of tire would fill their requirements for tires they have.
I'd think they can save far more fuel by concentrating on RR.
In order to keep the contact patch the same, the rim would need to be wider and the tyre would be stretched wider than necessary - that would give it more frontal area than needed - so that extra drag would need to be overcome before any benefit will show.
On 100mm of sidewall and 10°, you're looking at 18mm each side, that's a bit of stretch but I've seen worse on ricers.
Old 03-25-2012, 02:42 PM   #12 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
I dont think the frontal area would increase that much. Normally the tire is fitted like a donut so its much wider than actual contact patch. Then it just goes back to same width as the contact patch. More wider part would come on the higher proportion so its almost behind the front bumber or front tire spats.
https://www.facebook.com/photo.php?f...type=3&theater
Center of the tire is low rolling resistance compound and outer edges more grippy...
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 03-25-2012, 05:31 PM   #13 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Ford Hydrogen Fusion 999 Photo Gallery - AutoblogGreen
That tire is stretched and is there any other reason for that in speed record car than reduce drag?
Old 03-26-2012, 06:44 PM   #14 (permalink)
mikehallbackhoe
honda crx - '84 honda crx 1300
90 day: 55.83 mpg (US)
finally got my new tires 165 70 13, and all 4 rims the same size. ride is more quiet, and it seems to have more power. my old tires max psi was 36, and these are 44 psi. took a while to convince the tire guy to air them up to 44, but he finally gave in. can"t wait to go through a tank and check the mpg.
