Old 03-24-2012, 03:13 PM   #16 (permalink)
aerohead
visor
Originally Posted by some_other_dave View Post
You had "http" in there twice. Try this one:
http://i1066.photobucket.com/albums/...ght579x362.jpg
To embed it, you use the img tag inside square brackets: []. Then the URL for the image file, then /img in square brackets. The result is:
-soD
The fiberglass fairing on the upper leading edge when applied to a bus,with a 140mm radius ( 5.91") reduced drag by 12%.
By placing the straight-sloped ramp visor in front of it will cause the flow to overshoot the roof,causing immediate flow separation and higher drag.
Texas Tech's Aero Lab has investigated this sort of thing and it's REAL BAD.
flying kurmaster (03-24-2012)
