Old 03-25-2012, 10:20 AM   #11 (permalink)
GRU
GRU's Avatar
silver bullet - '00 Honda Civic
90 day: 34.41 mpg (US)
i got really lucky with this car.
I ran the engine yesterday for much longer than i usualy do and all of a sudden i noticed steam coming from around the distributor area so i thought "crap, the head gasket is gone too" so wasn't impressed with that. I get in the car and turn on the heat just to make sure it works and it's only cold air.
I get some water and start pouring into the rad because it was empty. As i'm about to finish i notice water pouring onto the ground so i look around and there is a small hole in the hose going to the heater core
Now it runs great, has no oil leak or coolant leak. The "bad oil leak" was the coolant leak but because the coolant was flowing on the oil coated engine it got really dark so that's why i thought it oil leaking
