Old 03-25-2012, 10:20 AM   #11 (permalink)
GRU
GRU's Avatar
silver bullet - '00 Honda Civic
90 day: 34.41 mpg (US)
i got really lucky with this car.
I ran the engine yesterday for much longer than i usualy do and all of a sudden i noticed steam coming from around the distributor area so i thought "crap, the head gasket is gone too" so wasn't impressed with that. I get in the car and turn on the heat just to make sure it works and it's only cold air.
I get some water and start pouring into the rad because it was empty. As i'm about to finish i notice water pouring onto the ground so i look around and there is a small hole in the hose going to the heater core
Now it runs great, has no oil leak or coolant leak. The "bad oil leak" was the coolant leak but because the coolant was flowing on the oil coated engine it got really dark so that's why i thought it oil leaking
Old 03-25-2012, 10:35 AM   #12 (permalink)
ZX - '97 Citroen ZX Monaco
OldContinents
90 day: 61.05 mpg (US)
That was certainly a lot better than having a real oil leak
Old 03-25-2012, 10:53 AM   #13 (permalink)
good luck with the car!
Old 03-25-2012, 11:22 AM   #14 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
that is very good news!
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 04-13-2012, 09:19 PM   #15 (permalink)
GRU
GRU's Avatar
well this car has made me smile. I got it all fixed up (not pretty) but it's good. Total cost including the cost of the car is about $1400 and i just filled up today, 35mpg, that's more than double of my old Ford Escape. Fuel just went up to about $1.35 per liter ($5 per gallon) so i'm looking at moding this car and hopefuly get about 50mpg
Old 04-13-2012, 11:09 PM   #16 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Cool - good going!!
Did you figure out if it's really an Si or something else??
I think those might be "JDM" lights on the rear. My '97 has much more conventional rear lights. Don't know for certain whether they changed those lights for your year, or the previous owner changed them to look more cool.
Coast long and prosper.
Old 04-13-2012, 11:30 PM   #17 (permalink)
cbaber's Avatar
Lean and Mean - '98 Honda Civic HX
90 day: 46.69 mpg (US)
From just looking at the outside pics this is not a real SI. Someone simply placed a badge on it. SI's had body colored moldings, 15 inch alloy wheels, better seats, different gauge cluster, and most important they had a B16 motor which is DOHC VTEC. This motor develops 160 HP and has an 8000 RPM redline.
The chassis might be a real SI, but someone could have swapped out all the Si parts for a regular civic. Only real way to tell is to run a VIN check and see what trim it is from there.
In a regular situation I would say you got ripped off since its not an SI but since we are ecomodders you lucked out by getting the better economy motor for really cheap!
1998 Honda Civic HX - My Project Thread
Old 04-14-2012, 12:08 AM   #18 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
They're Ebay Altezza-style ricer lights probably installed by a 17 year old. Nothing JDM about them. (Called Altezza after the Toyota of that name, aka Lexus IS300)
Putting in stock ones would be a great idea.
Great buy, by the way. Looks like it has great potential!
Old 04-14-2012, 10:46 PM   #19 (permalink)
GRU
GRU's Avatar
It's a Canadian SI which is the same as US EX model. It has the d16y8 motor with vtech. yes that taillights are gay but untill i find some cheap stock ones they will do the job.
Today i installed a kill switch so i'm hoping for some better numbers on the next fill up
