Welcome!
The biggest problem any of us have is adjusting the nut behind the wheel!
Go to the 65, and 100 tips at the top of the page.
Don't be afraid to bump up your tire psi. by at least 5#'s.
Work on SMOOTHNESS so stops are slower, and more gradual. Anticipate stoplights
ahead to avoid full stoppage if possible, and reduce accordian effect.
Live your life at 55mph., and much lower if possible.
Find routes to your destinations where you can cruise in high gear 35-45mph. w/o
having to stop much.
The most effectiveness is also the cheapest: learn to control yourself, and not drive w emotions.
Read, read, read! You'll find it will come natural to you faster than you might think!
06 Chev MonteC JG#24tribute car 30mpg 00 Honda Insight 63MPG 98 Buick Park Ave3.8 33MPG 89 Toyota Corolla wag 53MPG so far 81 VW Rabbit diesel pu 50MPG+ 80 Mercedes 240D stick 30-ish 90 vette 6-speed,29ish 07 Honda ST1300 55MPG 83 Honda 650 GL 64MPG 19 Suzuki dr200 88MPG23 HondaGrom?+Tow K10D Sub 26mpg NEVER,NEVER GIVE UP!
PUMP THOSE TIRES UP!
DRIVE IN YOUR SOCKS FOR SENSITIVITY!!!!!!!!!!!!!!!
SLOW DOWN AND SMOOTH UP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
