Old 03-26-2012, 01:12 PM   #417 (permalink)
dmerle
Black_xA - '06 Scion xA
For my manual transmission 2006 xA, what should I set cutoff to? With my foot off the gas, TPS reads 10. When I changed cutoff from 24 to 14, I didn't notice any difference in when I was seeing 9999mpg. I am only on my first tank - will this change once I calibrate after the next tank?
If I'm coasting in neutral (engine on), I would think it should not show 9999mpg since engine is idling? Should it ever show 9999? (I won't do EOC - I think it's too dangerous.)
-Deb S.
