03-22-2012, 03:28 PM
#411 (permalink)
It depends on where you are on the highway, that's all. At the closest convenient starting point, zero the Trip B odometer. I try to do this at a round number that is a multiple of ten so that it is easier to remember, but if you write it down, just use any whole number marker as your starting point.
Then drive as far as you need to on the highway, the farther the better; so obviously this is best done when you are actually going someplace. After you have driven 25 or 30 miles at least, note the number the Trip B odometer displays at the moment you pass that whole number marker, and write down the actual distance traveled vs the distance registered on the odometer.
Does this makes sense?
03-22-2012, 11:39 PM
#412 (permalink)
40-60-40 MPH P&G
did you see a difference in your highway mpg when you did your boatailing behind the rear tires? even if its 0.1l/100
Best Tank (1557.2 Km): 2.57 LHK (91.63 MPG (US) )
Best Highway Trip (~36.8 Km): 2.16 LHK (109 MPG (US) )
Best Commute Trip avg (73.8 Km ): 2.33 LHK (101 MPG (US) )
Echo-Troll Modding Thread
I know i dont have a very good write-up
no lean-burn? no good gear ratio? p&g is the answer
MPG=1 TIME=0
03-23-2012, 06:43 AM
#413 (permalink)
Yes, it did help some. I can say this because at first one was too wide and misaligned, and FE and coasting got better when I fixed it.
Mine are probably not as long as they should be, but I think that filling in part of the "void" is better than none. Also, they form part of the Kamm back.
If I ever get around to remaking the rear belly pan I had earlier, I'll have it stick out a little beyond the rear bumper to form more of the Kamm back.
You are already doing very well -- our chassis and drivetrain are virtually the same. What are your RPM's at say 65MPH?
03-23-2012, 06:58 PM
#414 (permalink)
40-60-40 MPH P&G
i dony know for 65 mph but at 100 kph i get about 2500 or 2600
MPG=1 TIME=0
03-23-2012, 10:41 PM
#415 (permalink)
Thanks -- 100kph is 62mph so that means your overall gearing is substantially taller than my xA. At about 65MPH my RPM's are ~3500. Sheesh...
Do you happen to know the final drive ratio? I'm guessing it is 3.56:1. Mine is 4.31:1 which is just silly.
03-25-2012, 02:02 PM
#416 (permalink)
40-60-40 MPH P&G
sorry i dont know my final drive ratio
MPG=1 TIME=0
03-26-2012, 12:12 PM
#417 (permalink)
For my manual transmission 2006 xA, what should I set cutoff to? With my foot off the gas, TPS reads 10. When I changed cutoff from 24 to 14, I didn't notice any difference in when I was seeing 9999mpg. I am only on my first tank - will this change once I calibrate after the next tank?
If I'm coasting in neutral (engine on), I would think it should not show 9999mpg since engine is idling? Should it ever show 9999? (I won't do EOC - I think it's too dangerous.)
-Deb S.
03-26-2012, 01:19 PM
#418 (permalink)
The TPS minimum on my 2005 xA is 12, so the cutoff may be different as well. I have the Cutoff set at 15.
07-05-2012, 12:25 AM
#419 (permalink)
Wow. It takes a while to read forty-two pages!
Keep up the good work!
07-05-2012, 06:08 AM
#420 (permalink)
Thanks -- I'm glad you found it useful. I was on Chronicle recently:
Thursday, June 14: MPG OMG | Chronicle - WCVB Home
Here are the links to the four segments:
Segment one [Blanchard hypermiler, Million Mile Joe].
Do you want to drive up your MPG? | Chronicle - WCVB Home
Segment two [propane car, Leaf, CarBEN EV5, Fisker Karma].
Ready to kick the gas habit? | Chronicle - WCVB Home
Segment three [Hobbit hypermiler, Blanchard, Chang 118 mpg].
How can you pump up your MPG? | Chronicle - WCVB Home
Segment four [Hobbit, MIT Solar Vehicle].
Powered by the sun | Chronicle - WCVB Home
