Old 03-26-2012, 07:02 PM   #13 (permalink)
RunningStrong
Panzerwagon - '02 Skoda Fabia
90 day: 53.88 mpg (US)
Originally Posted by Spencer Fitch View Post
I dont understand why though. I'm experienced in 4x4 offloading lifts ect. The only thing bad about going with taller springs and normal shocks is that you may bottom out the stock shock since it'll be no longer centered. I don't see why a car with a wheel travel of 3" cares if the shock is centered when it'll never bottom out.
It's a generally held opinion in the modifying community that shocks that were originally matched to stock springs have a shorter-than-expected life when later used with lowering springs. I believe it's because they are under a great and constant pressure due to the decreased stroke, but I can't say I'm an expert on it.
I actually have a scan gauge. Are the grill dams o my for when your cruising and plan for 0 traffic?
That's where the balance lies. My grill block is correx and cable ties. Should my engine temps start to peak in unforeseen conditions I can just snip them off and easily replace them.
