Hi folks,
I have ~4,000 miles worth of driving coming up toward the end of April. Between now and then I have maybe one or two days free to improve the aero on my MKIV Jetta TDI. That means it has to be something relatively easy to do.
Currently I am getting ~60 to 65mpg cruising at ~60 to 65 mph on level ground with the TDI. I've done only minor aero mods (see grill block below), installed a taller 5th gear, and installed LRR tires. Just this past weekend, I installed a skid plate which seemed to help FE a little bit. And the stock wheel covers are relatively smooth already.
Grill block:
Wheel covers:
I will probably have time to do ONE of the following:
- Full under tray (probably not a one day project)
- Rear wheel skirts
- Home Depot Air Dam
- Smooth(er) wheel covers (probably won't gain much)
- Passenger mirror delete (probably won't gain much)
Your thoughts on which to do? Best aero mod for the effort?
