Old 03-28-2012, 01:24 PM   #19 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by mja1 View Post
california98civic - do you have any small logger or scan gauge device able to measure engine knock? A widely used way to tune for gas mileage is to increase advance until knock then back off slightly, but then because you have no access to multiple tuning tables (VE, spark, throttle, pressure, airflow, rpm etc), you'd have to test for knock at WOT to be safe, then back off if it was knocking some at WOT
I have a scan tool that I bought for diagnostic purposes, and it offers some data my ultra gauge does not. But since I don't have a MAF sensor, I would not have that data on the tool either. By "spark" do you mean a timing advance readout or something else? Because the timing advance data would be inaccurate once I jump the system and start changing timing at the distributor.
Have you thought about a Hondata tune or do you already have one?
I have thought about Hondata, and looked into it. My specific OBD2 ECU is not ideal for their services, though other 6th Gen Civic trim levels are (such as the EX). I wish I had a 2005+ HX. Its redesigned ECU is specifically cited as one that Hondata will tune for MPG if desired. That would be cool.
Originally Posted by mwebb View Post
peak combustion pressure will happen before the piston has reached TDC
which is
bad
this is a very bad idea -
This would be true with a more aggressive advance, which I did not do, and with more aggressive driving, which I don't do. I advanced 2* and the car never crosses 2500/2600 RPMs. It will sit at lower cruise levels soon, when I switch-out the final drive gear for a VX 3.250:1 gear.
Lastly, I advanced the timing last May and have driven at least 10,000 miles since then. I'm fine.
Thanks for your concern and for offering your cautions to readers.
[EDIT: btw, I just remembered that one of your fixes I already do... I have been running 89 Octane for months.]
