Originally Posted by SOUL-DRIFTER
That is true about propane, but propane is used solely as a gas and has not been used as a liquid spray for a good comparison. Gasoline is sprayed as a liquid form into the engine and not as a true vapor.
I ordered the plans back in the eighties and was looking for someone who had done the same and gave it an honest try.
I think the point was that propane is a gas, so its a good comparison to gasoline thats been completely vaporized. If the claims of increased milage were true, you should see the same increase using propane. You have to correct for the btu/lb content, but thats simple. Since I haven't heard great claims of better milage with LP, I don't think just completely vaporizing the gasoline is going to get you much improvement.
Michael
