I just did the fuel injector cutoff on my 1995 civic vx. way easier than I would have even thought. I used the extra accessory spot next to the rear defroster as that is closest to what I am used to using when I was just doing the key turn off method of E.O.C. . The ability to use the right hand which is already in the process of shifting into neutral as opposed to having the switch control of the steering wheel seemed more safe and accessible to me. the only problem I have had was once when I didnt switch the switch all the way back, I was on the freeway and was a bit worried, had to get to the side and stop to figure it out. stopped using it for a while then used it again in my normal safer conditions and found out the problem! Thanks Andrew fro the write up, I know you prob dont check this any more as you sold the rig a while back but thanks anyway!
