Old 03-31-2012, 08:26 AM   #8 (permalink)
MetroMPG
90 day: 51.82 mpg (US)
Which engine do you have in your Barina?
In North America, that bodystyle could have had anything from a 55 hp 1.0L, up to a 100 hp 1.3L. Obviously one needs less cooling than the other. Regardless, the advice given is good: while you closely monitor coolant temps, start with the upper block, then progressively block the rest, starting from the openings that aren't in front of the radiator.
