Old 04-01-2012, 12:11 PM   #4 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Originally Posted by bhut2180 View Post
My next step that I'll do is probably buy that expandable foam stuff, spray it in the wholes, cut and form it to look like what I have with the cardboard over it, then fiberglass over the foam. Once I get a good layer of thick fiberglass, Ill remove the foam from behind
The foam can work well. Make sure you let it cure for quite a while. Days. I have found it buckles, shrinks, and pits easily. I think Daox reported similar experiences in his "Pretty Prius Grill Block" project thread.
I suggest, actually, that you leave some of the openings in the lower grill in front of your cooling radiator. When the weather is warmer, you might regret permanently and irreversibly closing all those gaps. Duct the remaining openings directly to the radiator so all air entering the car is forced through the radiator. You might leave the fog light holes too, covering them with something removable. LED lights installed there could save battery life by decreasing use of your higher amp and wattage headlights in all sorts of twilight and weather-related driving conditions.
I'm looking forward to watching your progress!
