Old 04-02-2012, 02:08 AM   #3 (permalink)
Vekke
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Hi,
I have also a lupo 3L and long thread about its modifications.
So do you get the fifth gear on or does it just change to neutral when fifth should go in? Changing the gears should not effect the gear changing mechanism. Did you check thegearbox functioning with VAG com adaptation and clutch creep settings. That will thell you where the fault propably is. Probably some misangliments of that gear actuator.
Why did you put shorter fitft gear ratio?
How long did it take to change the gear and did you have to take the gearbox out?
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
