Old 04-03-2012, 01:09 AM   #8 (permalink)
Vekke
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
ok now I could believe that the problem is inside your ECU. It might have been programmed that with fifith the RPM`s should be something at certain speed. If you have too much variation it might protect itself and change to neutral :/.
What gear ratio did you put in and what is the percentage difference between the two gears?
Lupo 3L gears are:
1st 3,455
2nd 1,955
3rd 1,182
4th 0,813
5th 0,642 and If I remember correctly that is freewheeling
So your new fifth is probably too close to fourth etc :/.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
