Old 04-03-2012, 01:17 PM   #11 (permalink)
cbaber
cbaber's Avatar
Lean and Mean - '98 Honda Civic HX
90 day: 46.69 mpg (US)
Check out this thread: http://ecomodder.com/forum/showthrea...8-a-20513.html
This probably has something to do with why your alternator is not completely shutting off. Here is the important part:
1 - You must disable two of the wires to the 4P connector, not just one: the sixth gen Civic's "smart alternator" has a four wire connector (a "4P" connector) and a separate large gauge white power wire for the alternator's power output to the battery. On the connector, one wire is for the charging light signal (blu/wht), another is the power line (blk/yel) for the field windings, and the two others are signal and control wires to and from the ECU. If you cut only the power line (blk/yel) the alt will still power using the blu/wht charging lamp wire. I know this because I tested for it using short wires with male and female spade connectors. I interrupted one line at a time and then two at a time until I was able to shut the alt off. You must interrupt both the blu/wht and blk/yel lines. A similar discovery was made by "busypaws" for his 1997 Protege DX alternator switch (he resolved the problem differently).
1998 Honda Civic HX - My Project Thread
