Old 04-03-2012, 04:07 PM   #13 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Good luck with the further tests! Please report more on your findings. Nothing cooler than testing something and being willing to admit if the test has failed, if it has failed.
And I like the FE results you are suggesting (which confirm my similarly sketchy results). It would be nice to know if the alt really was off.
One observation: your design is simpler than the one I posted, and that cbaber linked above. But the only extra thing I did was unplug the charging light wire near the driver's side firewall grommet, right? That's reversible in 30 seconds.
Originally Posted by steffen707 View Post
Thanks for the link, that's also a good read, but I was hoping that the grounding method would provide a more simple way to achieve alternator shut off than having to disable 2 wires, also i've heard from some ecomodders that have done the 2 wire shutoff as described in your link and that didn't work either.
I know brucepick has had difficulty with the method I describe in the linked post, but he is not sure yet what the source of the failure is. I haven't seen any others mentioning problems. Who are you referring to?
I have a voltmeter on my dash, and for what it's worth to anyone: in 7 months my alternator has not once begun charging unless I turned it on. If I drain the battery below 12.5 volts or if electrical load brings the voltage down below 12.5, it stays there, the alt does not turn on unless I flip the dash-mounted switch. Quite handy, really.
Thanks again,
james
