04-03-2012, 04:15 PM
#22 (permalink)
Ideally, you should block your grille such that your cooling capacity matches your new, efficient driving style. Then you kill 2 birds with one stone: you get a somewhat faster warm-up (and retained heat), while also gaining the benefit of reduced aero drag.
Edit: another mod that would help the big picture is a plug-in coolant or block heater. (Though I wonder how common/available they are in the UK.)
