Old 04-03-2012, 11:26 PM   #5 (permalink)
NachtRitter
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
For the OP: What kind of distance are you talking about?
Grill block is a good idea... if you make it out of foam (e.g. pool noodles), then you can press fit it in the grill and if it ends up being too much (scan gauge tells you the water temp is too high... above 215*F for instance) then you can easily slip it back out again.
The Following User Says Thank You to NachtRitter For This Useful Post:
Hip001 (04-03-2012)
