Thread: PT Cruiser
Old 04-05-2012, 08:15 PM   #20 (permalink)
Wonderjava
PT Cruiser - '01 Chrysler PT Cruiser Limited Edition
90 day: 27.73 mpg (US)
Originally Posted by cleanspeed1 View Post
When the light came back on, are you sure it isn't for another part of the system? Was the code cleared out after the valve was replaced? I am going to refer you over to here Allpar has Dodge, Chrysler, Plymouth, and Jeep car, minivan, and truck information and you can look at the various tricks for dealing with Chrysler products. But my sense about your high mileage car is it's due for a tune up, O2 sensor replacement and a catalyst backpressure check just to get it back proper again.
the code was cleared and when it came back it was the same code that it gave before. i will look at the links youve provided, and hopefully get this situation taken care of. im tired of hearing the engine light beep when i start the car. how much is the tune up, 02 senser replacement and catalyst backpressure check usually cost? do i need to give an arm and a leg to get these items done?
