Old 04-06-2012, 12:30 AM   #7 (permalink)
hawk2100n
The 'Vic - '96 Honda Civic DX
90 day: 39.3 mpg (US)
Originally Posted by PaleMelanesian View Post
Nice car! I concur about using LOD instead of TPS. I like mid-80's LOD for pulsing. These cars respond VERY well to Pulse & Glide.
I found the Scangauge to read a little high on MPG. I have a 13% offset on mine. (in the fillup process)
So your scangauge routinely indicates that you get 79 mpg average? wow
I switch to LOD and I like it. The 80% range actually gives me better acceleration than I had been (driving, doing, making, having, odd verbiage) before.
I removed the power steering belt today as an experiment to see if the car is livable. I don't have a problem with it at the moment. My driving has been unusually limited this week compared to normal (averaging 124.5 miles per day) and my scangauge readings will not be trusted until an accurate fill. Right now the TANK AVG is 46.5 mpg.
Pale, what is the off event for your scangauge? 0 RPM? I changed mine to COM hoping that I could keep it alive during EOC but I am switching with the key so the computer still shuts off with the engine at first until I switch it back. Any workarounds for this? Fuel cutoff switch I suppose is the best solution to kill the engine.
Civic Build Thread
Your grammar is appreciated.
3.788 Civic CX final drive, air dam, 1st gen HCH 14" wheels and Michelin Defender 175/65R14 LRR tires
