Originally Posted by Tesla
What sort of engine was it, if it was a diesel, then I'd believe it, removing the restriction would improve economy considerably.
Do you still have the vehicle?, if so, as said above do it again.
Also, when was the filter changed before that & was it the right spec filter?
It was a gasoline land rover discovery. About a year later I drive into water over the windows offloading and got rid of it. air filter was new. As a matter of fact I tried replacing it with a highflow cone filter to no avail. But the difference with no restriction was incredible. It was no fluke. As I got way more miles to the tank than normal and I document all fuel consumption doing the math it came out to 22mpg from 16
