Old 04-06-2012, 03:44 PM   #67 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
Originally Posted by adamj12b View Post
Thinking about it now, the pump is designed to augment the little amount of vacuum that a diesle engine produces. Maybe its just enough extra to have good brakes?
No, diesels don't produce any vacuum - they produce pressure. The brakes on these trucks are hydro-boost, using the power steering pump for power. This pump you link to (and unfortunately paid money for) is to provide vacuum for the HVAC system, AKA the heater controls. Too bad I didn't do my research before I bought mine!
Originally Posted by mort View Post
Hi Mechman,
I see this at a local (to me) store. If I got one how could I test it to tell if it would work for you?
-mort
Wow, that's cheap. All you would have to do to test it is dead head the pump with a vacuum gauge and give 'er 12 volts. The gauge should quickly jump to 20"HG or more. A gauge doesn't have much volume to vacuum down, so it should happen almost instantly. My junky pump slowly pulls a gauge to 13.5"HG in 5-7 seconds.
However, going by the dimensions listed for your pump, mort, it is about the same size as mine, so I do not have much hope. I am watching a pump on eBay that is sold specifically as a brake booster pump for Hot Rods, like this one: Hella 009428087 - Hella Street Vacuum Pumps - Overview - SummitRacing.com
