Old 04-06-2012, 04:33 PM   #12 (permalink)
Spencer Fitch
Originally Posted by jdchmiel View Post
when you did this experiment, did any other variables change at the same time?
Did you go from a very small restrictive oem filter to no restriction, allowing the big piggy engine to operate with less vacuum? Do you have a vacuum gauge to measure changes being made?
Did your panty hose on the end of a hose drastically change the location air was being pulled from, ie from the relatively cold outside to the relatively warm inside, near an exhaust header or similar?
Yes.. Way less restriction is a given. No air temperature change.
One thing that did happen was it seemed the computer figured something out after a while and the engine would die when coming to a stop without giving it gas. Directly because of no air filter restriction
