Originally Posted by Doni_99
jtbo!
Another thing that came up in my mind. One of the reason for not using more liquid oil than 10W40 that my D6 likes drinking motor oil instead of diesel:/
When I used 15W40 the oil consumption was about 0,7L/1000km and 1,1L beside the 10W40. My car mechanic said that it's not a surprising thing although it was renewed, because this type of engines tends to consume oil.
What was your experience? Was your Volvo thirsty for oil??
Hmm, Citroen. I had a CX several years ago, I loved it, the shape of it, and and the unique solutions of it.
Best wishes and excellent consumption improvement for All!!!
Not very thirsty for oil, did not need to add if I kept oil change around 8000km, but that was the point where it started to use oil as well as more diesel, so I usually did try to change oils after 7500km. With oil changes between 10 000 it would be needed to add oil as that last 2000km took about a litre of it.
Turbo diesel, for example in 740 has bigger oil filter, which might be worth to get if price is close to same, I have heard that size in that actually matters.
