Old 04-08-2012, 04:34 AM   #68 (permalink)
Vekke
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Very nice looking undertray. If you drive higher speeds you might need some more connecting points. Specially in the front I needed to add a rigid bar to stiffen the panel. It started to hit ground first at 140 km/h speed and after that also at lower speeds. So it broke the panel a little bit.
Did you make a hole for the diesel cooler? If you have one there under the car you need to make a hole. Diesel will otherwise get so hot that the plastic tank will melt or that is at least a risk.
Tank venting is this piece what I took out:
You will get 10 liters of more fuel when you press that nibble when filling.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
