Old 04-06-2012, 04:28 PM   #61 (permalink)
Project EconoPolo - '04 Volkswagen Polo Twist TDi
90 day: 48.23 mpg (US)
Last weekend I fitted new lower suspension springs (as recommended by Vekke some time ago). I went for Apex springs for a 35mm drop front and rear. The whole job was completed in about 2 hours with help from my dad. We also fitted new front brake discs and pads as the old ones were warped and rubbing (thanks to kingsway for recommending I check those).
Quite a difference in spring size, and they're clearly quite tired old springs:
and the rears:
And a comparison of the ride height old vs new:
Tomorrow's job is to disable my aircon, and if the weather is nice I'm going under it to fiddle!
Viio
Amateur SolidWorks Flow Simulator
Link to my Project EconoPolo (aeromodding a VW)
Old 04-06-2012, 06:49 PM   #62 (permalink)
Strangely enough - since I dealt with my binding brake, my FC doesn't appear to have changed at all!!!
Old 04-07-2012, 11:28 AM   #63 (permalink)
A few jobs completed today, the first one being disabling the aircon.
I used an old belt and cut it into a strip, then used it to measure the required length for the remaining wheels. Then my dad took it to his friends at the motor parts shop and got a new one at the required length. Here's the old versus new:
And here it is fitted, with the aircon pump no longer whirring away! Success!
Viio
Old 04-07-2012, 12:47 PM   #64 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Your MPG has improved nicely with the mods and should improve even more when weather gets warmer .
Do you use venting when you fill up? I think you should be able to put 55 liters to your tank...
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 04-07-2012, 01:00 PM   #65 (permalink)
Venting? What's that?
New belly pan got fitted today:
Full write-up here:
http://ecomodder.com/forum/showthrea...pan-21344.html
Viio
Old 04-07-2012, 02:09 PM   #66 (permalink)
belly pan
She's lookin' like a Ferrarri under there! Really nice! The gods of the troposphere will be smiling.
Maybe not so for Big Oil.
Old 04-07-2012, 07:47 PM   #67 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
It's a contraption that prevents you from carrying extra weight disguised as fuel
That's pretty neat and tight around the rear wheels !
Nice job !
Old 04-08-2012, 03:34 AM   #68 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Very nice looking undertray. If you drive higher speeds you might need some more connecting points. Specially in the front I needed to add a rigid bar to stiffen the panel. It started to hit ground first at 140 km/h speed and after that also at lower speeds. So it broke the panel a little bit.
Did you make a hole for the diesel cooler? If you have one there under the car you need to make a hole. Diesel will otherwise get so hot that the plastic tank will melt or that is at least a risk.
Tank venting is this piece what I took out:
You will get 10 liters of more fuel when you press that nibble when filling.
Old 04-08-2012, 04:01 AM   #69 (permalink)
I certainly like the convenience of carrying 10L more so I don't have to fill up so often. I'll take a look at that, thanks for the guide Vekke.
I'm going to the gym this morning so that's about a half hour trip, I'll check the temperatures under the car when I arrive, including the diesel cooler to see if it will need a hole cut. I might need some more holes under the exhaust anyway.
Viio
Old 04-08-2012, 12:17 PM   #70 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
I dont think you will need to make any more holes for exhaust pipe cooling. I tested that in my Lupo with so that I drived the car like a lunatic for 20 km and then measured the pipe temperatures from small holes with laser temperature gun. I could touch the pipe with my hand where the smooth underside panel was.
First series of those high fuel pressure diesels that was a big problem that the plastic fuel tanks melted. Solution was to add that diesel cooler. I dont know if the fuel temperatures get so if you drive the car fuel efficiently.
