Old 04-08-2012, 07:54 PM   #40 (permalink)
brucepick
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Originally Posted by wagonef8 View Post
What functions are they I thought that was just for alternator
Speed sensor is one; that's visibly fed by the same fuse when you view the circuit diagram.
When I tested pulling that fuse I got a check engine light while the fuse was pulled. Stayed lit while I idled the engine for several minutes. CEL went away after I shut down engine, replaced the fuse and then restarted engine.
"All that work" is relatively little work when doing it.
Coast long and prosper.
