Old 04-09-2012, 12:17 PM   #4 (permalink)
mort
EcoModding Lurcher
mort's Avatar
Originally Posted by bandit86 View Post
before anybody jumps on this thread who hooked up a hydrogen generation kit and says it doesnt work, was the timing adjusted properly to take advantage of the fuel?
Yes, there are a couple of posts here on ecomodder that refer to this paper from 1977!
I know we are yet to see some conclusive evidence of it working, but the math seems sold. optimum air-fuel ratio for a gasoline engine is 12:1, being 12 parts air to 1 part gasoline. at 30 mpg -let me carry on in metric, I find it easier, 30 mpg is 7.8L/100kms. Alright, if you drive one hour at highway speed, youc car getting 30MPG or 7.8L/100 you would have used 2 gallons or 7.8L of fuel. at 12:1 air fuel ratio that should be 24 gallons of air, or 93.6L of air consumed with that fuel. It does not seem right, that amount of air does not sound right, but you cannot dispute the logic.
Hint:
Ideal A:F is closer to 14.7:1 and is mass. So 7.8 liters is 5.6 kg of gasoline (0.719 kg/l)
5.6 * 14.7 = 82.4 kg of air. Air weighs about 1.2g/l that's about 70,000 Liters of air... If the A:F for H2 is 2:1 you'd need 40 kg of H2 at 0.089 g/l that's about 449,438 liters. You might want to check your assumptions.
-mort
