Old 04-09-2012, 11:28 PM   #15 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
too flimsy.
not enough anchor points.
THe reason coroplast is the only thing that works is because it has rigidity. And is light wieght.
I bet the plastic ripped right over the screw heads.
you need big washers or actual strips of steel or alluminuun to put up against the plastic.
just a question......
did you read my very detailed thread on installing an underbody panel?
I edited it after I had done the install to reflect what I learned.
Could have predicted this result......
and to the other poster......have you read the numerous successfull coroplast panel threads?
metal/aluminuum is NOT the answer.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
