yeah, when your transmission finally craps out (probably around 200K miles or more) then I'd say consider the swap. I don't think the weight savings of the beta would be worth the cost. It's worth it though to find out if it has a 5th gear that can be swapped in for better hwy cruising rpm's That could easily be done at clutch time.
