If you remove the battery while the car is running you can completely fry your electrical system almost instantly. The battery acts as a buffer and is required for proper operation of the alternator. The alternator actually produces 3 phase AC and this power is converted in the back of the unit to DC through a series of electronics, diodes and capacitors. You could fry them, your computer or a dozen other things if you do.
Don't Disconnect the Battery with the Engine Running
Civic Build Thread
Your grammar is appreciated.
3.788 Civic CX final drive, air dam, 1st gen HCH 14" wheels and Michelin Defender 175/65R14 LRR tires
