How do you plan to balance while applying some type of stand mechanism, if you are still in the vehicle? Or does it balance well enough when stationary?
I would suggest a third small wheel/caster on a hinge mechanism, offset to one side that you could fold down from the drivers seat. Hinge, caster, and shear pin. That way you could deploy while moving and not have to worry about keeping balance.
