Old 04-12-2012, 09:54 PM   #11 (permalink)
VXinOAKTOWN
clunkergem - '95 Honda Civic VX
Buying aftermarket will not work in your car because no one makes an aftermarket manifold for it. On your car the cat is part of the manifold so if you replace it with aftermarket you will not have a cat, which is illegal. You need to find a used part, weld the crack (they have been known to crack again after welding) or buy a new OEM manifold from Honda.
Essentially I converted my exhaust to a regular civic exhaust with header, downpipe, cat, then midpipe.
I agree, these seem to be the only options right now. I think that taking it to a good exhaust shop to have them weld it is the best option right now.
I don't want to convert the exhaust system if I don't have to.
BTW it looks to me as though the manifold and cat are two separate pieces.
