EPES required MPGuino recalibration
After driving several tanks with the EPES which runs mostly around 12.5V instead of the alternator's approx 14V, I found my MPGuino consistently reporting somewhat more fuel usage than the car actually consumed.
I expect that the fuel pump is running at somewhat reduced pressure at the lower voltage. So for any given injector pulse length, less fuel is being injected. The MPGuino reads pulse length, so needed an adjustment for use with the EPES.
Anyway, the correction I needed was right around 3%.
FYI. YMMV.
Coast long and prosper.
