Originally Posted by SiVX
Question:" My 185 tires are 10.8% larger than the VX 165s. Does this mean my RPMs for a given speed should be about 11% lower than normal?
Thanks for the help.
Yes, you are traveling 10.8% faster than what the speedometer says, so if your speedometer says you're doing 100km/h, divide your RPM by 1.108 to get the corrected value, or drive 10.8% faster.
