04-14-2012, 12:48 PM
#23 (permalink)
FLOW-IMAGES (brain food)
Originally Posted by RiderofBikes
haha, yeah my resale is a bit off at the moment  .
Well, the thing with the front end is, the way the panels are covering the front, its like hitting a ...wall. around 10" high of it at least if not more...
Now my Edited pic is more like the contoured shape of the template. While perfect aero may require a blunt edge/surface, it contours from the lowest point, not 10" higher than the bottom right?
A tapered edge or surface allows for better airflow around an object correct?
^That is what im trying to accomplish  . Making a wedge/contoured front end may solve the "wall" issue that i see. See pics for better explination
Anyone else have ideas
You might want to take a look at the above mentioned thread.You will see that the air is displacing around the nose far out ahead of the car.
