Before you get to wild with your mods .....
I love the design of your car and looked at one at a dealership.
However,I was absolutely shocked at just how terrible that the underside of the Fiesta and Focus are.
This ...is a
good thing in your case
Add a full belly pan, and i predict very good results.
Now about the front grille: From the factory, your car comes with much of the grille plugged. rather than add a piece of coroplast to the front of an already covered grille, you can keep the factory look of the grille ( have your cake and eat it too ).
The rest of the grille that is not plugged can be plugged using something painted in a matte black finish.
No one will ever know it is there except you.
Stealth.
Regarding covering the 'fog light' area, there has been some discussion on this site about the current generation Prius' use of this indention and body crease just before the curve of the front fender to form a clean separation at the front of the car.
Unless you plan to fully cover your front wheels, you may actually be causing
more drag.
The best way to test this is to leave one side covered and one factory stock and perform a tuft test.
From the factory, Ford tweaked the area around the wheels and gave your car little spoilers in front of the wheels. A lot of time was spent perfecting these, as some studies have shown that these simple plastic 'tabs' actually contribute a significant amount to drag reduction.
Again, if you add to this area, it would be a good idea to tuft test the area to see what the airflow is doing.
As far as adding a pointed nose to the car, may I ask why ?
Cars are not fighter jets that break the sound barrier, and unless you go above around 300 mph, the best shape to have is that of a rounded egg....something you have already ! ( as Sven7 has shown in that fine plan view image )
( Note how that the template image has a rounded front end versus a point.
As I'm sure you are well aware, the point belongs at the
rear of the car )
I think the wheel skirt is great though !
