Originally Posted by Blu3Z3rg
The reason, whether it's right or not, would be that the exhaust gasses get burnt a second time in the cat and therefore should take up less volume. Do a cat back and you'll see some power and mpg increase.
If you do a catback with 2" all the way through, maybe with a straight through muffler of some sort (flowing proper cfm isn't the only thing, a smooth flow is necessary) then you will see your best gains for the money.
can you show the data you input to come up with the 2" size .
