Old 04-14-2012, 06:27 PM   #3 (permalink)
1carnut
Sparky - '07 Toyota Prius Base
Voltage_kwh - '18 Chevy Volt LT
90 day: 151.04 mpg (US)
Voltage_gas - '18 Chevy Volt LT
90 day: 43.38 mpg (US)
I tried to take a picture of the back of the switch but I couldn't get it to turn out. Basically there are 5 what I would call pins that a plug (harness) would slide over. Since I am not using a factory plug, I need to find a good way to connect the wire from the PGM FI unit to one and run a wire back to where the PGM FI wire came from to complete the circuit from the other pin. I think that the others are used for the light in the switch and ground which I am not worried about. My thinking is that with the switch pushed in the injectors would be on and with it out, off. I looked for the grey box marked PGM FI and did not see it. Will have to take a closer look.
