Old 04-14-2012, 09:19 PM   #96 (permalink)
mcrews
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
Originally Posted by SiVX View Post
Can someone with a stock vx please crawl under the car and give me a pipe diameter? or circumference if thats easier for u... the vx I bought recently has an aftermarket pipe from the exhaust manifold/cat. then it has a 2007 SI muffler added. and yes i have googled and tried to look up replacement parts for the sizing but they dont give me all that info wherever i find parts.
I've read all the stuff about less back pressure at higher RPMs. I plan on maintening those lower RPMs for lean burn and FE. Seems to me trading it off for a stock would be the thing to do??? I'm confused lol
I still don't have enough info for the pipe calculator. Dont know where to find valve opening BTDC or closing ATDC or duration...
Thanks!
sivx,
your civic new produced max 92hp at 6000 rpm.
you need a single pipe in the 1 1/2 diameter
based on the chart above.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
