Hey Sean,
After reading through everything you posted, I don't think an electric conversion is the best way to go.
The current stats on my cycle at 20 mile range and 45 mph top speed - just as you said you want to go for.
My cycle weighs 400 lbs.
Load weight onto your cycle until it weighs 400 lbs and go coast down a hill. See how it steers and how the suspension bounces. I don't think it will work out too well.
This is a very "scooter-esqe" style frame. Cool looking, but where do you put the batteries? My cycle has dual down-pipes, so I have room for the batteries to mount on.
I would echo comments about repairing/replacing the engine. Gasoline or diesel pack a lot of power in a small size. For a lot less weight and space than batteries.
I think my batteries hold the equivelant of about a pint or less of gasoline!!!
Yours is a cool little cycle, but I don't think it has the space or suspension for an electric setup.
Explore other possibilities of what you can do with this cycle. It could be a really cool little project.
I like the idea of a 150 cc engine with an aerodynamic fairing on it.
Best of luck,
-Ben
