thanks old tele man, but thats all for testing the ignition coil to make sure that its puting out the right voltage so the car will start. to low voltage the car will crank but wont start and you will see a spark but not a strong one to start the car. i'm looking for maximun voltage output from a standard ignition coil ( inside the distributor cap ). im going to be installing a exsternal ignition coil outside the distributor cap for a higher voltage output, this is why im looking to fine out what the maximun voltage output is.
